Page 1 of 2
Side Stand
Posted: Fri Feb 28, 2025 4:56 pm
by Duccout
Has anyone here managed to graft a side stand onto a Ducati Single? There are various aftermarket side stands available for the bevel twins that use the rear, lower engine bolt as the fixing point, so I wonder if the same could be done for a Single?
Re: Side Stand
Posted: Fri Feb 28, 2025 6:37 pm
by DBDBrian
Hi Colin, side stand pictures from a Ducati Singles forum. I have thought about making one, as it's handy when parking on grass, but I tend to think they look a bit clumsy .
Re: Side Stand
Posted: Fri Feb 28, 2025 7:19 pm
by ranton_rambler
I bought a proper one from Richard Bool at Stafford Show. Fixed to front engine plate. I’ll try and remember to take a picture tomorrow.
Re: Side Stand
Posted: Fri Feb 28, 2025 8:39 pm
by Eldert
Hi Colin
did you have a look at a 450 RT desmo sidestand ? it think that is what you are looking for
Re: Side Stand
Posted: Sat Mar 01, 2025 12:02 pm
by Duccout
Thanks everyone.
Eldert, how does the RT stand fit to the bike? Is it bolted to the footrest plate?
Re: Side Stand
Posted: Sat Mar 01, 2025 2:38 pm
by ranton_rambler
Here’s my side stand, in both positions.
I think it’s normally fixed to the left hand plate but this one had been chopped so I just fitted it in addition to the engine plate. Tucks up neatly under the motor although I added the little spur so I could deploy it from the seat.
Re: Side Stand
Posted: Sat Mar 01, 2025 3:07 pm
by Duccout
Thanks for the pics. The problem with the original side stand is that they cost a fortune, which I don't mind, except my bike has the parallel twin frame and so I am not sure that I could get the mounting plate to fit. It may be possible, but it is an expensive exercise if it is not.
Re: Side Stand
Posted: Sat Mar 01, 2025 3:54 pm
by blethermaskite
Colin, is it for a widecase or narrow? the widecase is pretty easy using the footrest fixing 'plate' as in Elderts photo.....you can use quite a few Jap bike side stands that bolt onto their frames with a bit of mounting bracket 'modding' the last one I made was from a Honda nsr 250. Cheers, George
Re: Side Stand
Posted: Sun Mar 02, 2025 9:15 am
by Duccout
Hi George,
It is a wide-case. Thanks for the info, I may get a used side-stand and try to make up a bracket to fit. I cannot see how the 450RT stand is fixed, the parts book does not show it.
Re: Side Stand
Posted: Sun Mar 02, 2025 9:37 am
by graeme
The pic Eldert provided shows the stand attached to the bracket that fixes to the rear lower engine bolt and the unused lug ( Desmo) with an 8mm through bolt just forward if the lower rear engine bolt.
Scrambler uses the 2 bolts to attach the foot peg brackets.
