Aye George,
Thanks Bill, how do you start the 450 without a centre stand?
Stand to the left-hand side of the bike, hold both bars, free the clutch by kicking over the engine, with the kickstart a couple of times, and with the clutch pulled in. Release clutch and exhaust valve lifter.
Now bring the piston up, with the kickstart, to TDC and with the fuel taps on and the enrichment valve on the AMAL MKII carburettor raised, with the exhaust valve lifter open, give the kickstart lever 2 to 3 good swings, so as to prime the cylinder, with air/fuel mixture.
Return the piston to TDC, with the exhaust valve lifter closed. Now with the exhaust valve lifter open, ease the piston over TDC, with gentle pressure on the kickstart lever. DO NOT SWING ON THE KICKSTART LEVER! Release the exhaust valve lifter.
Turn the ignition "ON" and then with a swinging kick to the bottom of the kickstart arc, turn the engine over. The engine should fire and run, slowly reduce the enrichment to zero, by lowering the enrichment valve and within 30 seconds the engine will idle at a steady 1,100 - 1,200 rpm.
If this procedure fails to start the engine, initially return to paragraph: "Now bring the piston up, ....." Repeat and the engine should run. If not, turn the ignition "OFF", lower the enrichment valve and with the valve lifter open give the kickstarter 5 to 6 swings, so as to purge the cylinder and then start the procedure at "Now bring the piston up, ....." again. If the engine refuses to fire you have "A problem Houston!" and will need to check fuel flow to the carb, fuel on the plug and spark at the plug.
Keep the weight of the machine resting on your right-hand thigh and feet apart, when attending to the fuel/enrichment levers.
Swing a leg over, engage gear and ride off on another jaunt, allowing the engine to warm through in the first 3 to 5 miles and then give some throttle.
This all reads like teaching my Grandmother to suck eggs, to the owner of a Ducati single of 50 years!
But then yours being a 350 MKIII, I suspect that you have always just turned the fuel taps "On", tickled your AMAL MKI carb tickler until the fuel flowed, selected 2nd gear, pulled the piston back onto compression, set off at a jaunty canter, with the clutch pulled in and once up to a good gallop, launched yourself, side saddle onto the seat, dropping the clutch at the same time and been wafted off into the blue yonder on your magic carpet!
This is still possible with the 450, but my balance and nerve for doing it on public roads isn't what it used to be !
When the 450's engine decides to cough or die at the traffic lights, as it can do on the odd occasion
I usually just dismount and use the kickstart to get the piston to TDC, ease over with the valve lifter open, close the valve lifter and a good swinging kick restores operations. If not, the shove of shame to the nearest refuge follows.
Starter button????
Having initially, learnt my kickstarting technique on various AMC singles, the latter being a '53 AJS 18S, and being right footed, I have never been able to adopt the left foot prod to start left-hand sided kickstart engines, I just become discombobulated and don't have the strength/co-ordination in that leg to do the job.
