Engine cutting out from full throttle to idle
Posted: Wed Jul 10, 2024 5:45 pm
I've started to use my bike a bit now and really enjoying it but have a persistent issue which I first thought was fuel starvation due to Indian tank not venting but now beginning to wonder if it's someting else.
Bike starts and idles OK.
No issues accelerating all the way thru' the rev range.
Bike pops on a closed throttle but stops if throttle cracked slightly.
First time I noticed the problem was after filling fuel tank and riding it about 3 miles, bike cut out and stopped at side of road, wouldn't start. I removed and refitted petrol cap & bike started straight away and no issues on rest of ride.
I thought i'd fixed it by drilling a vent hole in cap but it leaks fuel so blocked hole for now until I sort out a baffle arrangement on cap.
Not had an issue for a while but recently had the bike up to full throttle for a while doing approx. 60mph ish and as soon as I came off the throttle the bike cut out but started again once I started blipping the throttle. This has now happened a couple of times so wondering if anyone has any ideas?
Bike is 450 R/T on scrambler road gearing.
Electronic ignition (Electrex STK-164)
Original carb.
Pod filter (K&N copy)
Spark arrestor fitted to end of open exhaust.
I've pulled the plug (NGK B7HS) and it looks normal with a light brown insulator & electrode looks OK.
I did wonder if the cone filter was too small and although the flow area is a lot less than standard it should be big enough from the calcs I've done.
The carb stub stack does butt up against a shoulder in the cone filter so air flow will be pretty rubbish going into the carb but not sure it it'd be any worse than the convoluted hose of the original setup?
Debating about replacing the air filter with either a pukka K&N pod filter or standard/scrambler paper filter and housing.
Not sure how much back pressure the spark arrestor is causing but not sure I'd get away with open exhaust on the road even for a short time.
Any ideas?
Original carb.
Any ideas?
