Get rid of your battery - if you have a kick starter
Posted: Fri May 31, 2024 8:34 pm
I've had to drop out of the last 2 motogiros because my bike died due to the battery dying due to over charging. Blaat (Jim) is also facing the same problem although I think he may have a stator problem now.
(1962 Ducati 200GT) I have been been having an "overcharging" issue since I replace my weak original 2 wire / 2 stator, flywheel and (doesn't exist) RR with a modern ones. I've tried two different RRs with the same result, four blown batteries over the past year. I bought some diodes (rectifiers) and was trying to lower the voltage from the RR before it gets to the battery. I was also going to use a small capacitor to smooth the voltage. I was hoping that those two techniques would result in a lower smoother voltage which would be better for the battery.
I found one 4 diode rectifier bridge and wired that between the RR and battery. (https://octopart.com/datasheet/vbo40-08no6-ixys-4006460) It dropped the voltage but rectifier got very hot. I didn't trust is to hold up. So I decided to get rid of the battery and I installed a 15V 10K uF capacitor. I bought this one because it had a spring mount. https://www.hughshandbuilt.com/product/ ... capacitor/ You can find cheaper ones but I recommend getting a name brand with screw in posts. https://www.electronicsurplus.com/mallo ... 00uf-15vdc
Today with just the capacitor it started on the first kick. I just got back from a 56 mile ride and everything works as it should. The voltage is 7.4 with lights off and 6.9 with lights on. My batteries would blow up at around 30 miles so I hope this is the fix for my motogiro woes.
