My Technical Contribution - WC Bevel Gear Simulator
Gang - I have attempted to unwind the mystery of timing dots through my own two bikes and lots of reading on here. I wanted to be able to simulate what the gears look like in various phases of rotation. You can even then imagine (I wish I could illustrate) the olham coupling that is only correct (based on bevel tower setup) once every 10 rotations.
https://geargenerator.com/beta/#0oyRw2Y ... inJGYXdT$5
This link should take you to my attempt to recreate the Bevel timing and gears.
I have had to stack gears on axles to simulate the bevel top and bottom tower gears as well as the two gears on the crank for bevel tower and oil/timing.
If you play with it, note rotation on the crank gear. After 10 crank rotations, everything aligns again as it should. The dots all work well until you get to the oil gear idler that feeds the timing gear. Due to limitations of this software, I cannot put two dots to indicate the second set for the timing gear to line up. The dot on the timing gear here is really just indicating rotation, so I chose bottom so I could eyeball it. What do you think?
1968 Ducati 250 Scrambler (US)
1972 Mototrans 250 Road
Re: My Technical Contribution Gear Simulator
In my simulator everything lines back up after 10 crank rotations, except the oil pump gear, which doesn’t really matter since it is a idler gear. It is driving the timing gear which does indeed return to SAME starting point every two rotations. So I think this model is good. Helpful for anyone????
Users browsing this forum: Google [Bot] and 157 guests
