Broken clutch boss bracket
Wheels have been polished and rebuilt. My 73 Road 250 is coming along nicely. Now the engine.
1968 Ducati 250 Scrambler (US)
1972 Mototrans 250 Road
Re: Broken clutch boss bracket
Fairly common! I don't know if it happens when the adjuster rusts into the boss and the swelling splits it, or the subsequent attempts to remove it does the damage, or maybe it happens when someone is trying to split the cases and whacks it; I suspect the former; either way it is a good idea to always grease the adjuster.
I have seen a repair effected by bolting a steel plate onto the adjacent crankcase bolt and passing the adjuster through this, but I don't see why you could not get a weld done on it and then re-tap it and cut the slot, although it may be difficult to do without an engine strip.
The only aesthetically original repair would be to build it up with weld, shape/machine back, but that would ideally mean an engine strip.
Alternatively as mentioned by Colin a bracket bolted to the rear crankcase mouth bolt can effect a repair. This is a common mod to narrowcase engines used for racing when using the longer Widecase arm. See below a couple of pictures to give you an idea of what is involved.
Nigel
Nigel
Re: Broken clutch cable bracket
I can easily design this and have my brother make this for me, as he is a Tool and Die guy, but are these sold anywhere ?
I don't think so, certainly I have never seen one.
Users browsing this forum: Google [Bot] and 153 guests
