Does this thermocouple advise make sense?
Posted: Tue Sep 19, 2023 2:11 pm
by mrkprsn
How does checking for voltage across the yellow generator wires using a thermocouple voltmeter work?
Don't you use this to check temp differences? Do I connect the pos lead to one gen wire and the neg lead to the other gen wire and test for volts?
I thought testing for volts would show the difference between each wire. I would expect that to be 0.
Re: Does this thermocouple advise make sense?
Posted: Tue Sep 19, 2023 2:54 pm
by themoudie
Aye mrkprsn,
As this is an electrickery question, "I know nothing!". But from reading your questions, I would be of a similar mind. Thermocouples measure heat, probably due to material resistance (?) and testing for volts uses a voltmeter circuit. But as to the "How?" a thermocouple or voltmeter circuit works, not a clue!
However, the inserted image is so small that it is illegible! And I cannot magnify it either!
Sorry not to be more helpful.
Posted: Wed Sep 20, 2023 1:47 am
by MonzaMan
Hello:
I wondered the same thing when I read that a couple months ago. My guess is that they are referring to a type of volmeter and the intended message was lost in translation between Italian and English.
Maybe they meant to say 'analog' voltmeter. Sometimes watching trends on a digital voltmeter is difficult if the voltage is jumping around. With an analog meter one would see the needle rise and fall with engine rpms. You would see very readily if the alternator is working...
Best,
D
Posted: Thu Sep 21, 2023 7:02 am
by Ventodue
As Bill, Mark:
"However, the inserted image is so small that it is illegible! And I cannot magnify it either!"
And as MonzaMan:
"My guess is that they are referring to a type of volmeter and the intended message was lost in translation between Italian and English".
Over the years I have learnt that it's often best to read manuals and such like in the original Italian. Apart from the usual subtleties and nuances that occur between different languages, it is often apparent that the translators lacked the necessary technical knowledge to describe things correctly.
Here's an example: the radiator expansion tank on my Laverda 750 is describes as a "nourrice" in the owner's manual, the parts book and the workshop manual.
So what's one of those when it's at home?
Posted: Thu Sep 21, 2023 7:24 am
by IanHood
"So what's one of those when it's at home?" - in French 'nourrice' can be translated as 'wet nurse' which seems strangley appropriate for an expansion tank
Posted: Thu Sep 21, 2023 8:59 am
by themoudie
Steady Ian!
I never thought of a Laverda 750 expansion tank as being voluptuous!
Posted: Thu Sep 21, 2023 10:16 am
by IanHood
Me either Bill but there are some very strnge kinks in this world...
Posted: Thu Sep 21, 2023 3:34 pm
by mrkprsn
Here is a bigger pis. Click on it. Cheers, Mark
download/file.php?id=7425&mode=view
Posted: Thu Sep 21, 2023 5:21 pm
by George
Disconnect the two yellow cables. Set your multimeter to alternating voltage of 200. Start engine connect multimeter probes to yellow cables. Doesn't matter which way round for ac voltage, when revving bike voltage should increase. Let us know what readings you get. Good luck
