Lower Bevel Bearing Question
Posted: Sat Jan 14, 2023 5:12 pm
I am rebuilding a basked case 160. Yes, I know many might ask 'why?". I bought it a number of years ago for $100 and am rebuilding it to learn more about these single motors as I have a few more to rebuild in the queue. It's not a good investment, but I don't care, I am enjoying myself.
The motor is apart and cleaned. I pulled the lower bevel bearing housing out with an extractor that I purchased from eBay. Nice tool. I pulled it because the bearing action felt a bit gritty. Once the bearings are out of the cage they feel fine. I put in new bearings and now they feel gritty once in the cage. I am going to assume that this isn't normal and the rotation should be as smooth as butter. A very tight cage might cause a minimal reduction in clearance or deformation of the bearing, however, it does not require extreme pressure to install or remove, especially since I have taken them in and out a few times.
I'm just looking for confirmation that the rotation should be smooth and any suggestions. I don't have a lathe or any machinist tools other than a 12 ton press. Thanks.
