Friction Damper
Friction Damper
I thought it was odd that my 350 Scrambler did not have a friction damper. The chrome nut at the top of the steering stem has a hole but the stem itself has no hole for the rod to go through. Most singles I've seen have a damper. Is this something common to Scramblers?
Re: Friction Damper
The steering stem has no provision for the rod to pass through. Maybe I should take a picture of the bottom of the lower triple clamp.
Re: Friction Damper
Here's a bottom pix.
Re: Friction Damper
Here's a top pix without the crown nut that has a hole in it.
Re: Friction Damper
It has the same loose balls in the cup at top and bottom of the frame neck. They are tightened down by the flat nut shown in the pix.
Re: Friction Damper
Here is a pix at the bottom triple clamp.
Re: Friction Damper
could the original tube been damaged and someone replaced it with the solid steel rod? It certainly looks strong!
speaking of friction dampers, what are the friction washers made of? Mine no longer offer any friction.
Re: Friction Damper
MotoMike wrote:speaking of friction dampers, what are the friction washers made of? Mine no longer offer any friction.
I would like to know this too. It kinda resembles a linen phenolic.
