Winter is over
Re: Winter is over
...and a new clutch pressure plate. The saved weigt ist not impressive and there is no improvment in clutch operation noticeable ...but it looks nice. The two Millimeter clutch plate was provided by Carlo Leoncini from Motofficina Leoncini.
Re: Winter is over
i modified my pressure plate by adding a Suzuki thrust bearing . works great and i still can adjust the clutch
Re: Winter is over
I put some holes in my 350's pressure plate, but removed much more weight from the clutch housing, with my big drill press and an angle grinder.
It must accelerate faster.
Re: Winter is over
Jordan,
well done! I like the pattern of your design!
Wolf
Wolf
Re: Winter is over
Thanks, Wolf.
I thought it might need to be balanced after the hand held machining, but there is no increase in vibration.
Users browsing this forum: Paul W. and 173 guests
