Crankshaft missing shim?
Posted: Wed Apr 21, 2021 1:14 pm
by Dodge
Reassembling my Mk3 Widecase. Should there be a shim between the end of the main crankshaft (alternator side) and the bearing in the crankcase cover? There is one (#0150 29 050) on the kickstart shaft but I don't find one on the main crank. The parts manual does not show it but it might fall between two diagrams.
Re: Crankshaft missing shim?
Posted: Wed Apr 21, 2021 2:36 pm
by Duccout
Are you talking about a shim between the flywheel and main bearing? Usually there will be shims fitted.
Posted: Wed Apr 21, 2021 4:32 pm
by Dodge
No, between the bearing in the cover and the end of crankshaft.
Posted: Wed Apr 21, 2021 5:26 pm
by Duccout
I don't think so.....Anyone?
Posted: Wed Apr 21, 2021 6:00 pm
by blethermaskite
No shim needed there.
Posted: Wed Apr 21, 2021 6:38 pm
by Dodge
Thanks, just seemed strange that there should be one on the kickstart shaft (relatively not much rotation) and not one on the crankshaft that is rotating all the time the engine is running.
Posted: Thu Apr 22, 2021 5:52 pm
by blethermaskite
The shim on the kickstart shaft is there to control excess end float and to stop any wear on the inside of the clutch cover case, the crankshaft endfloat is controlled by shims on the crank mainshafts inboard of the main bearings in the crankcase, so the crank doesn't need shims out at the clutch cover outrigger bearing.
