Page 1 of 8
It only took seventeen years.
Posted: Mon Oct 12, 2020 9:08 pm
by DBDBrian
After quite a few hurdles to overcome, my 1959 200 SS engine is assembled and ready to install in the refurbished frame.
Re: It only took seventeen years.
Posted: Tue Oct 13, 2020 6:41 am
by Duccout
Only seventeen years?
Posted: Tue Oct 13, 2020 7:29 am
by blethermaskite
It will almost be a pity to use it, these engines really are pieces of automotive sculpture
Posted: Wed Oct 14, 2020 2:29 pm
by Rocla
Yes, il is a too beautiful engine to be mounted and used on a motorbike. Anyway, congratulations for such work
Posted: Wed Oct 14, 2020 9:10 pm
by DBDBrian
Thanks all for your comments, yes they really are a lovely looking little engine, but it was not designed to look at, so it's back in the frame, and lets hope it lives up to expectations when it's fired up.
I did quite a bit of internal scheming with with the rebuild as it had had quite a hard life, it now has a late type clutch in the early cases. and a few other mods.
There was not too much which did not require attention, including the frame and fittings.
I have now got to the stage, where apart from making the control cables and wiring harness, most parts are ready to assemble.
I have lost count of the hours, but then that's the fun and satisfaction in bringing something back to life.
Posted: Wed Oct 14, 2020 9:56 pm
by themoudie
Now! That will be a bonnie looking machine Brian and I am delighted that you will give it some welly!
The early mods will hopefully play ball and make your life easier to ride and maintain the bike.
Good health and the time to enjoy it out for a canter. Bill
Posted: Thu Oct 15, 2020 12:49 am
by graeme
Brian, that is a credit to you.
(nice work shop too!)
Posted: Thu Oct 15, 2020 6:55 am
by Duccout
That looks super, I can see the detail that has gone into the rebuild. We look forward to the finished bike!
Posted: Fri Oct 16, 2020 5:47 am
by ranton_rambler
Looks very good Brian.
Just for my education, you have studs and nuts holding the head down but mine has long bolts. Is that standard, or a modification?
Posted: Fri Oct 16, 2020 9:36 am
by DBDBrian
Hi Ian, yes the studs are a mod, two of the threads in the crankcase where shot, so I helicoiled all four. The reason I used studs rather the the original bolts, is the studs can be installed (with copper slip) making full use of the length of the insert, and there is no torsional load on the insert when tightening the head down.
I made the studs from 316 stainless rod, and the nuts from aluminium bronze to eliminate galling, with a 10x1 thread.
The downside being they would have to be removed to take the head off with the engine in situ, but there is enough thread to use double nuts for removal.
