Page 1 of 2
Fuel Taps
Posted: Sun May 17, 2020 7:06 pm
by frankfast
My '71 350 Scrambler has dual petcocks with 6mm outlets yet the 29mm VHB carb has a dual banjo with 8mm inlets. I'm suspicious that either the tank
(or petcocks) or the carb is not original to the machine. Or is that the way Ducati did things back then?
Re: Fuel Taps
Posted: Tue May 19, 2020 11:15 am
by Ventodue
Sounds like it's the taps that are too small, Frank. See photo below (1972 450 SCR, btw). The caliper jaws are over the outlet spigot, of course.
Re: Fuel Taps
Posted: Tue May 19, 2020 11:38 am
by frankfast
I think you're right. It's reasonable to assume that the 350 and 450 Scramblers had the same size taps. I'm not sure that having a smaller tap would cause a problem with feeding the carb, especially because there are two. Getting a fuel line to accommodate both is the issue.
Re: Fuel Taps
Posted: Tue May 19, 2020 6:00 pm
by amartina75
The 450 uses 12 mm threaded taps 250/350 uses 10mm threaded taps
The barbs on the bigger taps are 8mm and smaller taps are 6mm although they may have made later small taps with 8mm barbs they are available at Guzzino
Dellorto also made fuel inlet fittings with 6 and 8mm barbs
The carb on your bike may have came from a 450 or something was swapped over the years. Your 350 scrambler probably originally had an SSI29D on it. It’s hard to say without seeing several pictures of the bike to see better when it was produced.
Re: Fuel Taps
Posted: Tue May 19, 2020 8:03 pm
by frankfast
The information I have reads that the earlier 350 Scramblers had the 29mmSSi carbs while the later models, '70 to '74, had the square slide 29mmVHB. Since I don't have the history of the bike it could be that the taps or the complete tank were not original to the bike. Since I believe the barbs on the carb to be correct at 8mm, I probably should change the taps on the tank. So that the lines don't leak, I have to crank down hard on the hose clamps over the 6mm taps in order to keep them from leaking. Eventually they will cut into the fuel line and start leaking.
Re: Fuel Taps
Posted: Tue May 19, 2020 11:59 pm
by amartina75
Yeah it’s hard to say for what it’s worth I have a VHB on my NC 250 Scrambler and I was able to fit new 6mm Tygon tubing over the 8mm carb inlet (it’ll never come off but that’s ok)
You can buy new 8mm petcocks that might be the best route depending on the condition of yours. If they are original I’m surprised they aren’t leaking. The old rubber seals don’t like the ethanol in modern gas.
Good luck sorting it out
Aaron
Re: Fuel Taps
Posted: Wed May 20, 2020 7:48 am
by Ventodue
amartina75 wrote:The 450 uses 12 mm threaded taps, 250/350 uses 10mm threaded taps. The barbs on the bigger taps are 8mm and smaller taps are 6mm although they may have made later small taps with 8mm barbs <snip>
That's good info, Aaron! Who would have guessed? Thanks!
Re: Fuel Taps
Posted: Wed May 20, 2020 11:31 am
by Jordan
The size difference could be even worse.
I measured some barbs on various Ducati tanks and carbs, and the range is from 5.5mm to 8.5mm.
It might be worth considering making some mid-line adaptors that can accept two different sized hoses.
Re: Fuel Taps
Posted: Wed May 20, 2020 3:21 pm
by frankfast
If what you're saying is true, then my tank, taps and carbs could all be original equipment. Can't believe Ducati could have used 6mm barbs at the tank and 8mm barbs at the carb. Then again.... Or is what you are saying the range of barbs are on different models.
Re: Fuel Taps
Posted: Wed May 20, 2020 4:45 pm
by amartina75
Keep in mid Ducati didn’t make any of those parts, they sourced what was available from Italian companies at the time. Even the gas tanks were outsourced as far as I know. Don’t remember who produced them but I’ve seen pictures of a makers mark inside gas tanks.
Also parts are swapped over time with whatever works and is available.
I think what Jordan is pointing out is that the tolerance between parts were pretty loose.
