Re: rich running
Posted: Sun May 10, 2020 12:29 pm
Possibly teaching my granny to suck eggs, but if you’re using your degree wheel on the timing shaft, have you allowed for it running at half speed?
An on-line community of Ducati single-cylinder motorcycles
http://www.motoscrubs.com/forum/
"Static ignition timing adjustment for the 250 singles equipped with the most recent pointless CDI"
With the aid of a piston stop and a timing whell, find the crankshaft's T.D.C. position as precise as possible. Then, block the crankshaft in the 54° before T.D.C. position (angles for 350 and 450 given below). In this position, the edge (1) located on the rotor must align with the little notch (2) on the stator plate. In case of mismatch, rotate the pickup stator until edge and notch are aligned.
Scottish888 wrote:The pickup on the red plastic backplate looks ok, no cracks in the potting, they are just steel plates according to a moto morini site <snip>
Scottish888 wrote: I see a lot of new similar transducer/coils for fantic and other trials bikes around 40 euros but they are for 12 volt I guess
Scottish888 wrote:It would be very helpful to be able to test the pick up and transducer functions but I think there is no info out there on this.
ducwiz wrote: Studying the schematics, especially the circuits connected to the alternator windings will explain, that the CDI circuit and the Battery/charging circuit are not electrically connected <snip>
ducwiz wrote:Now, for the pickup: the hint about the internal diode caused me to pull my spare pickup from it's storage box <snip>
Duccout wrote:I can definitely say that a lot of people changed to points from the CDI in the late Seventies and early Eighties when the electronic systems began to break down, as I remember the discussions about it.
