Page 6 of 34
Re: Strada Camshaft Oil Ways
Posted: Mon May 11, 2020 1:01 pm
by Ventodue
double diamond wrote:Perhaps use the NC single spring 0550.12.040 which is 119mm in length? I also have one that I believe is mislabeled that is 110mm.
110mm is right for some n/c models, altho' it would seem not with that part number
. See my post above.
Posted: Mon May 11, 2020 10:35 pm
by double diamond
My interchange book shows 200VS.CA54 supersedes to 0550.12.040. The 110mm spring might be a NC side stand spring?
Posted: Fri May 15, 2020 4:01 pm
by Duccout
Update: I managed to buy a really good oil pump from eBay, which arrived today, so after a good clean I fitted it. It actually has a ball valve, unlike the Mototrans one, which also has a weird housing on the outside of the pump body, possibly this is a kind of pressure relief valve? The body looks quite different to a Bologna one.
I had also discovered a lot of free play in the bevel coupling that I never noticed when fitting the head, so off with its head again and fitted a 0.01 undersized bush, which is pretty tight on the shafts and has taken out almost ( but not quite all) of the play, and while the head was off I helicoiled one of the cam end cap threads that was on its last legs.
Because the remnants of the exhaust port threads only have a tenuous grip, I thought it prudent to fashion a bracket to support the exhaust pipe, which is fixed next to the footrest.
The bike started first kick, which was nice, and I had left off the bevel cover to check that the oil pump was working; for a low-pressure pump, it sure pumps the oil at a furious rate! So that is it for now, until DVLA return to work and send me a log book, there is not much more to be done, except wheel the bike outside and give it a good wash off.
Posted: Sat May 16, 2020 3:00 pm
by Ventodue
double diamond wrote:My interchange book shows 200VS.CA54 supersedes to 0550.12.040. The 110mm spring might be a NC side stand spring?
Curious. Definitely shown as 110mm long centre stand spring in this 1959 200 Elite book ...
(Apologies for hi-jacking your thread, Colin
Posted: Sat May 16, 2020 3:38 pm
by Duccout
Some of the Mototrans part numbers do not tally with Bologna, so I don't see how anyone can know whether certain parts are interchangeable without trying them. Take the 250 Strada camshaft, Mototrans part no: 0603 29 10, which is the Bologna grey cam...But it isn't. Bologna grey: inlet 62/76 ex 70/48; Mototrans grey: inlet 68/95 ex 84/78. Take the bottom bevel crank gear, both have the same part number, but apparently the two are not interchangeable, because Bologna used a different tooth pitch to Mototrans.
There may be many parts where Mototrans deviated from Bologna's specifications, to suit their own production lines, but kept the common part number.
Posted: Thu May 28, 2020 8:07 am
by Duccout
After deliberation on whether to dispense with the rev-counter, last Friday I ordered a new Smiths copy from India, expecting delivery to take weeks. This morning it was delivered by FedEx, which I think is pretty amazing. I don't know if the thing works, but for £11.50 including postage, it sure is a good deal!
Posted: Fri May 29, 2020 7:15 am
by Eldert
Hi Colin
from what Guzzi and supplier you used the exhaust nut ?
and would a picture of the item be possible ?
Thanks Eldert
Posted: Fri May 29, 2020 8:08 am
by Duccout
Posted: Fri May 29, 2020 9:31 am
by Eldert
Thanks Colin
found 1 in the Netherlands for 45 euro .
Posted: Fri May 29, 2020 2:35 pm
by Duccout
Surprise! My new rev counter reads about 1000 RPM under, so it looks like I will be returning to the original plan of dispensing with one. There is a reason why things are cheap!
