Strada Oil Pump - No Ball Valve?
Posted: Fri Mar 20, 2020 3:30 pm
I've been having masses of fun discovering the horrors contained within my engine - bottom bevel sleeve loose in the housing and both bearings broken up, leaving the bevel gear free to rise so that it barely made contact with the crankshaft bevel. The teeth on the crank bevel are badly chewed up and broken.
While the timing cover was apart I thought it prudent to inspect the oil pump, and found that at some point the bike had been run with the drive tang not engaged in the timing gear, so that the oil pump gear had done a passable imitation of a milling machine on the pump back plate. Apart from that, there is no ball valve on the pump and no hole in the back plate for one, so I'm assuming that the later Mototrans bikes never had them?
Time and time again, when I need some odd part or spare, I search through my junk accumulated over 45 years of Ducati ownership and find what I need. It just goes to show that I was right to never throw anything away. I found the rubber-mounted inlet manifold from my 350 from 40 years ago, cleaned it up and sleeved it down and bored it to 27mm and it will live again on the Strada.
