R-R for 12 Volt conversion
Posted: Sun Nov 17, 2019 12:30 pm
from time to time threads about converting the nasty 6V electrics into a 12V version. Therein some chinese R-R's are often mentioned. Here is my recommendation: This https://www.ebay.com/itm/223467332827 is the cheapest R_R for a conversion to 12 Volt I could find on ebay. It can be used with the alternators of all w/c singles (points or CDI), and after a slight mofification of the stator on the n/c singles with the 60Wat alternator.
Important: if you find a different seller, his R-R must have 5 wires and the same sequence of wire colors as depicted in the ebay offer. Exception: the pink or orange wire may also be yellow, like https://www.rexs-speedshop.com/product/universal-single-phase-regulator-rectifier-110w/.
