Hi Folks,
Found this info online at the green spark plug company, thought it would be helpful to know.
I have no affiliation in any way with that company
"We get asked the same question regularly - which is the better manufacturer - Champion or NGK, generally the problem lies with modern plugs and this is our thoughts.
If the engine hasn't started straight away you will probably have wet the spark plugs up. Once the spark plugs have been coated on the inside there is a possibility that an additive which has already been added by the manufacturer to unleaded petrol causes the spark to track down to earth. Even with wire brushing and trying to burn it off it will carry on doing so. We have been told cleaning with oven cleaner does help but we have not tried this.
A good tip when replacing new plugs is to have your engine already started and warm first on the old plugs, then put your new plugs in. The highest resistance with the spark is when the plug is new and unused.
There is no technical report on this but selling plugs for 30 years these are our conclusions.
Also Donald Mckinsey has written about it in the United States and here are his thoughts on the problem
Donald Mckinsey
Are you having problems finding a spark plug that lasts very long in your old engines?
First let's define the problem with the new spark plugs. When the automobiles became controlled by computer, the spark plugs did not have to have the bottom of the insulator glazed. The cars have fuel injection and the computer will not put enough gasoline into the cylinder to flood it. It injects fuel into the cylinder and says I will not put any more fuel into the engine until it fires. Then it fires the cylinder with 4O,OOO volts, if something happens to this computer control and too much fuel is injected into the cylinder, and the engine floods, this vehicle will not run right until you have taken the old plugs out and replaced them with a new set. What has happened is the trash gasoline the Federal Government has forced on us has contaminated the spark plugs because they are not glazed on the bottom. However when was the last time you flooded a computer controlled vehicle? More than likely, never.
Now these old engines do not have computer control and if your carburetor is running rich or you flood the engine, the same thing happens. The bottom of the insulator where it fires the engine becomes contaminated and becomes junk. The point coil or magneto ignition does not have 4O,OOO volts to fire the spark plug.
The solution to this problem is to find the spark plugs that were manufactured prior to the time that they quit glazing the bottom of the insulator. (Around 1975-77..) In those engines that used 1/2" pipe thread spark plugs or 7/8 - 18 thread spark plugs, the best deal is to try to buy spark plugs that come apart so the insulator can be taken out and cleaned with WD-4O, kerosene, Diesel fuel, or other things that will not remove the glaze on the bottom of the insulator. In any case, do not sand blast or glass bead them. This removes the glaze and you have a short life plug just as though you had purchased one of the newly manufactured spark plugs.
Those plugs that do not come apart, but are glazed on the bottom of the insulator can be put in a can of the same material mentioned above and set over night. Then brush the carbon and oil out of them with an acid brush or other small brush. After cleaning them, blow them off to remove the excess cleaning liquid and you are ready to run again.
I cannot emphasize enough that spark plugs should not be sandblasted or glass beaded. Also that to get any length of life in the old engines, they must have an insulator that was glazed on the bottom.
DONALD MCKINSEY, P.O.BOX 94, WILKINSON, IN 46186."
useful spark plug information
Re: useful spark plug information
I use a Champion aviation spark plug tester/cleaner. I use the proper cleaning grit from Champion. I have no problems cleaning plugs. I can't imagine the FAA would let spark plugs be cleaned if it meant they would rapidly fail. Just my opinion.
Our shop did find, though, that modern fuel formulations can be problematic with certain plugs. This would depend on your local fuel formulation which may well be different from ours. It started in the early 2000s. You would put in a new set of plugs in and the car would come back in a day or so refusing to start. Not just old cars. Current vehicles as well. Clean or replace the plugs, and you would be back in business. Even weirder it would only affect certain vehicles and not all vehicles of the same spec! Very Strange. It only happened with the base NGK plugs. If you fit Bosch plugs, no problem. The fouled plugs would fire just fine in the open air. You had to pressure test them to find the failure. We contacted NGK tech support and they were aware of the issue and suggested we switch to their platinum or iridium plugs. This does indeed solve the problem. However, cheaper Bosch plugs did as well. So we dropped NGKs and switch to Bosch.
Hi JB,
That was exactly the issue I faced with my 81 Bonneville, 20 year old Champion N5's worked but I fitted new NGK's with advice from a forum, bike run fine for 50 miles over a few days but was running lumpy near the end. Later I tried to start my bike, it was impossible, all I got was the odd backfire. Tried the old N5's, bike started and run. Of course you cant believe your virtually new NGK's cant be working, they looked clean and sparked on the head but once fitted refused to fire. New NGk's fitted would fire the bike up and it repeated the same after 60 miles so maybe there is something sense in the info. Why would a 50 mile plug not work but a 20 year old plug would. Anyway I have bought a new Champion and a new NGK for my Ducati 250. The Champion is the L82c hope it is the right choice as a L86c was also mentioned
Users browsing this forum: No registered users and 76 guests
