Hi All,
Has anyone got a definitive list of all the variants of vertical bevel shaft lengths on singles?
Re: vertical bevel shaft lengths
Info I have recorded:
Source: Phil Hitchcock (Road and Race)
w/c 250 = 182mm (same part as n/c 350)
w/c 350 = 192mm
450 = 202mm
n/c 175 to
250 easy to id due to wasted shaft.
Unfortunately Phil didn't give the lengths of the n/c 175 & 250 shafts.
w/c 350 = 192mm
450 = 202mm
n/c 175 to
That's very helpfull, thank you.
Are these measurements from the underside of the top bevel gear to the end of the shaft or the total bevel shaft including the gear? And I'm assuming this is the measurement for just the upper bevel shaft and not the lower? Aren't all the wide case lower shafts the same length?
