For a 350 with a dual plug setup, what plug options are you fellers going with? Yeah, I know it’s very bike specific but a baseline (primarily for the second plug) would be appreciated.
For what it matters, Omega hi Comp Piston, Lacey 277 cam, coil springs, 7mm 40/36 valves, Electrexworld crank mounted ignition, custom exhaust with Cone Engineering silencer.
Spark plug options
Re: Spark plug options
C7HSA for the secondary plug. B6HS for the primary.
For race use NGK grade 9's both plugs.
Nigel
Nigel
