I’m looking for a manifold to mount a Dellorto PHF 32 or 34 on a Ducati single. It’s aluminum, has a 42mm diameter neck and a 52mm stud spacing. I've attached a picture but I also have it here. http://huisinga.dyndns.org/home/manifold.jpg
I’ve searched every online store I can know of but can’t find one of these manifolds. Can someone point me to a source for one?
Jack
Bainbridge Island, WA
Manifold for Dellorto PHF 32
Re: Manifold for Dellorto PHF 32
Hi Jack
never seen this manifold before . years ago Malossi made manifolds for the single for a rubber mounted carb .
manifold tapers from 34 to 30 mm .
Seems like a standard 900SS item for the rear pot.
That makes it rather rare, You're not the only one looking for it.
I don't have a source, just keep searching at il mostra scambio
ciao
ducadini
ciao
ducadini
Try Phil Hichcock at Road and Race in Australia
Phil had some made a few years ago and has been waiting for more to be made.
They were longer than needed which let you cut them to suit your carb position.
Yes I had seen from online stores that the 900SS rear manifold looked very close - except that they were for 40mm carbs and I thought that the stud distance was more than 52mm. I'll check with Phil. thanks
Hi Jack,
Talk to Malcom at Syd's cycles, and see his catalog website, https://sydscycles.wordpress.com/catalog/ .
Click on the green "Syd's Cycles catalog" banner, and look at page eleven. The catalog is a download...(which means you won't see the catalog on his website, it will be in your downloads)
Syd Tunstall made my manifold years ago, when he was still there, but Malcom(Syd's son,) will have what you need, they are a dellorto distributor.
Bruce
Bruce
Jack,
I'll attach a photo of a manifold that would meet your specs- the 750SS and 900SS have 58mm stud spacing- the 750GT and 750 Sport have the 52mm spacing you're looking for, but the GT and Sport front manifolds and GT rear are the elbow style, so you want a Sport rear manifold, like this:
The rear Sport manifold is really hard to find- I have a manifold that looks like a 'cut and shut' job on the elbow style manifold:
The GT manifolds are easy to find- cutting the 42mm barrel from the manifold and some time grinding and welding would get you what you need.
I got my new manifold from Phil. It's the rear Sport manifold and it will work as the pictures posted by Rick. It's 33mm which is just right for the 34mm carb I'm fitting. Thanks all for the suggestions. It's still a mystery where my original came from because it is not the sport version. Maybe it's from Syd's but I don't see a picture there.
Jack
Jack
Users browsing this forum: No registered users and 30 guests
