I very much doubt if this is a "new" topic but, I could not find the info I needed by any combo of words on the search page.
So could someone give me a safe value on the front and rear axle nuts on a 66 Monza ?
I know every body starts to laugh when we speak of torque values and our older bikes but, I would like to try and do this
the right way and not screw it up!
Any other proven assembly values are also most welcome.
Many thanks in advance.
Mike
Axel nut tourque
Re: Axel nut tourque
A common method is to keep tightening until the thread just starts to strip, then back off a little.
then it would be loose ????
And the thread would be stuffed ?
Some helpful links:
http://www.online-iso-calculator.com/online-bolt-torque-calculator-metric-vdi-2330/index.php?thread_standard_value=M16X1.5&standard_head_option=1&iso_head_organization=2&iso_head_value=18&strength_class_value=6.8&dkm_value=20.1&coefficient_value=0.14&select_friction_option=S&metal_coating_value=9&lubrication_value=0&yield_value=75&recommended_torque_80_value=190.4
https://www.norbar.com/en-gb/Home/Torque-Tension-Calculator
Results depend on the friction coefficients at the thread and under the head of the nut, which is uncertain. Additionally, the grade of the steel that axle and/or nut are made of is unknown, which gives more uncertainty. I presume a not too high grade for the axle, like ISO 5.8 or 6.8, the nut might have higher grade (8.8), and might carry a corresponding marking. However, the softer of both parts limits the permissible torque. I tightened the axle nuts of my 350D (M16x1.5) to 12-15 Nm.
ducwiz wrote:Some helpful links:
Thank you Hans. That's what I was looking for.
Oh, it'll stuff it alright, but it's still a common practice.
(It's not a serious suggestion.)
graeme wrote::o then it would be loose ????
