Zoomersmoto wrote:Is this colored markup of the magneto alternator correct for the 28 watt 6 volt Ducati Scrambler 250?
After scrutinizing the n/c workshop manual and other sources (see above) I conclude:
You posted the correct schematics for your bike (engine no. after 92171),
but the wrong picture for the alternator internals:
It belongs to the schematics for the early SCR (engine no. till 92171), ought to be associated with it:
Until eng. # 92171, a pure AC system was implemented, no battery, no stop light, separated AC ign. circuit. The wire colours might have been black, blue an unknown; those in the "at wits end .." post are different. the wires look quite new, like having been replaced.
Unfortunately, we do not have a sketch of the stator's inner circuitry. It's clear that your stator has no floating coil for lighting power, but indeed an inner ground connection, and two power outlets. We still do not know whether this "dual coil" is grounded on one end of the windings, or somewhere in between. This can possibly be found out by measuring the resistances
and by tracking the output cables down to their solder spots/coil ends.
You found in the post mentioned above:
White wire has 1 ohm
Green wire has .5 ohm
Black wire has .2 ohm
Then you quote:
His white should be yellow
His red should be white
His green should be red
Your wire colouring:
Our wires are different but give the following readings:
If you ground the ohm meter to the case
Well, I can't see any difference in colours when comparing yours and those in the other post
I understand that you scibbled the colours as depicted in the (correct) schematics of your loom onto the wrong stator schematics.
Now again: as long as we have no reference stator from somebody's stock, or your own at least visible in mounted position, we will not make any step further.
cheers and good luck Hans
