Fork strip
Fork strip
I have stripped the 31.5 forks of my 67 Narrowcase and its clear that the cowboys got there first. No internal small spring and loose balls from the damper 7 out of 9. The assembly looks different to the Clymer book so I'm a bit in the dark. Is there a decent exploded picture of whats supposed to be there?.
Re: Fork strip
Our dear forum master keeps copies of an article about that topic on the tech page: http://www.motoscrubs.com/Duc_Technical.htm
Scroll down to the end and find the links. They might help you.
However, the n/c fork and it's components must be listed in the parts catalog.
Re: Fork strip
Thanks mate, sadly there is no detailed info on the damper assembly in there.
Re: Fork strip
Hi Bob,
Do you have access to a Ducati shop manual?
There's a breakdown on page 94, illustration#107.
I don't have a way to upload a copy of it for you at this time but maybe someone else???
Bruce
Bruce
Re: Fork strip
Hi Bob,
I will set you up with access to a Dropbox where you can download the manual from.
Re: Fork strip
Thanks Guys, Now I have most of the parts its just a matter of understanding how the thing works so I can repair and assemble in the correct relationship. I think the valve is in upside down and there is no way of keeping the balls in place. No wonder my poor old joints protested at 90mph over the bumps at the IOM. The only damping I was getting was from the SAE 40 oil I put in.
Re: Fork strip
ecurbruce wrote:Hi Bob,
Bruce
And on page 95 the fitting procedure of the valve mechanism is described.
Re: Fork strip
None of the books I have seen actually show the valve clearly or describe how the ball bearings work , Some just say they don't give any trouble or advise to leave well alone!. I think the housing is staked on one side ,and the balls free on the other side ,held in by a (missing)washer which does not appear to have anything securing it, unless the(missing) spring does. I think mine is in upside down anyway. If it was really simple how come the well established bike shop who re-built it got it all so wrong?.Along with everything else they played with!.
Re: Fork strip
Bob
There were a few different valve designs.
One type has a few of the holes blocked off by staked in balls. If you see deformed metal at a few of the openings you have this type. it’s common for those balls to come loose in this type. Another type has less openings, where those staked in balls would be there is no hole at all. The last type has loose balls and all openings drilled.
The valve is held in the bottom of the fork tube by a snap-ring. There is a washer on top of the valve that holds the balls in place.
I can take a picture of the assembly later today if you need but here are a couple pictures that show the parts.
Aaron
Aaron
1966 250 Scrambler
Re: Fork strip
Aaron,
that is what all those who haven't seen that stuff yet (myself included) had been waiting for !
Thanks a lot Hans
Thanks a lot Hans
Users browsing this forum: No registered users and 24 guests
