ranton_rambler wrote:I am guessing the thing on the left is a rectifier/regulator, but I haven't looked at the wiring diagram yet.
Yup. I can't see it in the 175TS parts book (
), but you can find it illustrated (for example) in the 250 parts book.
ranton_rambler wrote:The thing at the top is some kind of rotary switch - can't see anything like it in the book.
Rear brake light switch. Altho' not the same model as shown in the parts book, it's the type that was common fitment on many singles e.g 160 Monza Junior. Activated by a spring that goes thru a small hole in the rod, something like this:
ranton_rambler wrote:The thing on the right is presumably a locking device?
Sorry, don't recognise that one!
ranton_rambler wrote:... the carb is an MB22 with 2 cable entry points. One of them operates the throttle slide ... The other is locked off on top of the carb. There would be no room under the tank to get a cable in. For cold starting device?
Yes, should look like this:
But, that said, I see there was also a lever operated version that looked like this:
I see that a replacement top complete with lever can be had from Paddy Ducati:
Or this version from Eurocarb:
ranton_rambler wrote:The parts books shows a little lever on the RH handlebar but I don't have this
Hmmm. Can't help you with that, I'm afraid. Maybe the simplest answer would be to fit a new lever operated top? Dunno ...
