Has anyone ever experienced or heard of the original aluminium front brake levers on early narrow cases like 175/125 Sport snapping under heavy braking?
Someone just told me they were "very dangerous" and "snapped by hard braking". I see replicas for sale that are made of chrome plated steel. Is this why the replicas are steel not aluminium?
Aluminium front brake levers snapping?
Re: Aluminium front brake levers snapping?
I’ve not heard that nor seen evidence of it. I’ve seen cast brake levers break from impact but the original Ducati levers are not cast. They are quite malleable. I’ve heated and straightened handlebar levers that were considerably misshapen without breaking them. Questionable origin replica levers are an unknown. I do recall a report that the brake plate anchor pin on steel slider forks such as the F3 and 175/200 motocross will break off where they are welded to the fork leg after many years of use. The 175 Sports that I have seen do not use the steel slider fork. Not sure about the 125.
Hi Lex
the guy that had them made up wanted to avoid anyone sueing him over a broken lever so he had them made up in steel .
i had aluminum clutch levers brake on me . i drilled the hole in the lever all the way thru and used longer nipples .
problem solved .
problem solved .
I had a repop lever snap for a vintage Honda. I told the vendor about it. Not only dangerous on the road, but razor sharp at the fracture. Mine snapped while taking a bike off a lift. Had heavy work gloves on.
I have never heard of any OEM lever snapping under breaking. Liability would be huge.
Regards,
Rob
Regards,
Rob
Snapping brake levers!
Test by squeezing hard with two gloved hands.
It'll give the cable nipples a good workout too.
I'd assumed aluminium alloy levers are cast by some method that avoids brittleness.
But maybe they are supposed to be forged?
Thanks for all the replies. I've never heard of an OEM aluminium lever snapping either. It's certainly never happened to me. Perhaps it is just an issue with replicas made of unsuitable material.
Lex
Lex
LexH wrote: Perhaps it is just an issue with replicas made of unsuitable material.
Lex
Or OEM that has been straightened without heat being used, or maybe just one to many times.
Whenever someone starts telling me what junk something is, my immediate thought is, "what did you do that might have contributed to that failure?"
CZ
Users browsing this forum: Google [Bot] and 45 guests
