crankshaft press
Posted: Tue Feb 02, 2016 10:36 pm
				Discussing Stan's crankshaft truing process has inspired me to finish the press that's been 90% done for several years. It's modeled after a photo of the factory press, but looking around on YouTube I've found these are common- especially with 2 stroke dirt bike mechanics.
Mine is a Danly die set- 4 posts are pressed into corners of the bottom plate(shoe) and 4 bushings are pressed into a mating top shoe- the top shoe slides on the posts extremely accurately- it's hard to measure any play when the posts and bushings are in good shape- these die sets cycle hundreds of thousands of times in industry with little maintenance.
The drawings I made were for a Ducati twin crankshaft, but it will work fine for a single with some reducer bushings.
The holes in the top and bottom plates are line bored to fit the bearing journals on the crankshaft. There's a small pocket in the shoes for the protruding flange on the crank flywheels to nest into- keep the pressure applied in a straight line to the pin. Press the pin into one flywheel, put both flywheels into the press with the connecting rods and press the crankshaft together.
The shafts on the flywheels should stay aligned as accurately as the plates were bored, which should eliminate lots of hammering on the crankshaft.
This is my bottom plate, a post , and a few different styles of bushings- steel, hard anodized, and a ball bushing.
Someone who works on crankshafts every day can probably get the same result with just a press and a hammer, but I feel better when there's not so much left to chance.
I don't have access to the kind of machinery needed to do the final drill/bore/ream, so I'm going to take this to a shop when the blizzard blows over- will report back how it works.
