Page 1 of 2
What carb set up?
Posted: Wed Oct 21, 2015 10:36 pm
by JJJ12345
I need help with a good carb/manifold set up. '64 Monza frame, '64ish scrambler motor. No carb or manifold on the motor when I bought it. Mikuni ? What size? Thanks to all.
Re: What carb set up?
Posted: Thu Oct 22, 2015 3:33 am
by pear0
For a 250 engine - a Mikuni VM 26 would work. Stock jetting to start .
Don't know about a manifold. Make one? TomA
Posted: Thu Oct 29, 2015 2:47 am
by pear0
Manifold -- Guzzino has some
Posted: Thu Oct 29, 2015 7:52 am
by Jordan
Amal carbs need no manifold, just an insulating spacer.
Studs on the head are spaced so the carb can be directly attached.
Spanish Ducatis used them.
Posted: Thu Oct 29, 2015 11:19 pm
by JJJ12345
Ok thanks for the info.[img]
[/img] Fits pretty close to the valve cover.
Posted: Fri Oct 30, 2015 8:27 am
by Jordan
If that's your bike, suggest you lose the bolts, and install studs in the head, with nuts to retain the carb.
It's more likely than studs to cause problems, and looks wrong.
You can space the carb from the head to your liking (assuming you can get the spacer), and figure out the length of the needed studs.
Posted: Fri Oct 30, 2015 10:07 pm
by JJJ12345
Might be hard to see, but those are studs .
Posted: Sat Oct 31, 2015 4:14 am
by Jordan
Sorry, thought it looks like a bolt head with a Torx socket in it - I've seen those.
Posted: Sat Oct 31, 2015 10:59 pm
by JJJ12345
No problem. Someone may have cut them off a bit?? Bought the motor in a box. Then bought a roller. Just trying to piece it together. Fun stuff. The carb is a 627 Amal 2 stroke. Just wanted to see if it would fit. I will find a right hand 626 and give it a try.
Posted: Tue Nov 03, 2015 3:45 am
by JJJ12345
Has anyone tried running a 26mm pwk keihin?
