Bottom bevel bearings.
Re: Bottom bevel bearings.
If the cases are heated and the bearings are kept in the freezer overnight they should drop in.
Re: crank shimming
You can't shim the crank "tight". If you do, it just pushes the crank out of alignment. You just shim to take out the play, that's it.
