Page 1 of 2
valve spring compressor
Posted: Tue Oct 28, 2014 1:58 pm
by Sam
Can someone post up a picture of the valve spring compressor for the Ducati springs please or has someone made something up to allow compression of the spring to fit the collets some measurements would be handy as well. Feel reluctant to spend £70 on something that will only be used once in a blue moon. thank you in advance. Sam
Re: valve spring compressor
Posted: Tue Oct 28, 2014 8:21 pm
by Jordan
Photos of factory tool, and someone's improvised version from a G-clamp.
Posted: Tue Oct 28, 2014 8:26 pm
by graeme
Hello Sam
I used a short piece of aluminium channel and a G clamp about 25mm long x 25mm ID x 30mm high.
The channel sits over the collet retainer and the G clamp foot under the valve face.
A bit fiddly but very cheap
Posted: Wed Oct 29, 2014 6:38 am
by Sam
Cheers for the replys I have ordered a cheap fleabay compressor which should easily be converted to take the above attachments.
http://www.ebay.co.uk/itm/390908393303? ... EBIDX%3AIT
Posted: Fri Oct 31, 2014 8:16 pm
by tobydmv
That kit should work nicely. I have a custom made adapter and use a large C clamp. The adapter is round but it still worked on the rectangular spring plate. Someone with a mill should churn out a few adapters in square fashion to fit the ducati hair spring tab. I would buy one.
Posted: Sat Nov 01, 2014 1:24 pm
by DucRedux
tobydmv wrote:That kit should work nicely. I have a custom made adapter and use a large C clamp. The adapter is round but it still worked on the rectangular spring plate. Someone with a mill should churn out a few adapters in square fashion to fit the ducati hair spring tab. I would buy one.
I too have used a large C-clamp in conjunction with a rectangular, metal electrical utility box cut down to bridge the valve springs. Imagine a box cut at about 2/3 and notched at the base at a width so that the valve springs lock in side- to- side which prevents slippage. See:
http://www-public.tnb.com/ps/fulltilt/i ... rt=5836134
Posted: Sat Nov 01, 2014 2:21 pm
by Sam
Cheers I will try with a piece of box section in the mean time I made a clutch holding tool
even found a use for the old clutch basket
a handy holding jig.
Posted: Mon Nov 03, 2014 5:27 pm
by Sam
Posted: Mon Nov 03, 2014 7:42 pm
by Jordan
Looks good, Sam.
Posted: Wed Nov 05, 2014 8:18 pm
by Recluse
Howdy all, new guy here. I made up a couple of valve spring compressors based off of another post here at Motoscrubs (can't find the thread now...)
They are simply a couple of .25" pins through a piece of 1" x 12" x .25" thick flat stock. Pins are held in by o-rings so they don't fall out and get lost. I had to grind off one corner of each where it interfered with the guide at full compression. To use them you take out the bottom pin, slide the tool through the spring and reinsert the pin. Easy and cheap!
