I want to remove the front wheel on my 250 scrambler circa (1968/69, not sure yet). I removed the nut on the clutch side of the front fork. Does the shaft pull out or do I have to remove the front fork? The shaft doesn't seem to move.
Any help is appreciated,
Art
Front Wheel removal
Re: Front Wheel removal
Hi Art
did you undo the pinch bolt on the bottom of the other fork slider ?
[quote= asmith411 ...
" I want to remove the front wheel "
____ First, prop-up the front-end of the bike by resting the base of the motor on a milk-crate or the like,, then after you loosen the fork-leg's pinch-bolt, pull-out the axle and-then the entire wheel should drop-down & roll-out.
Users browsing this forum: No registered users and 15 guests
