Seemingly compression comes and goes.
Posted: Sat Aug 23, 2014 8:22 pm
A couple years ago I put the Mach 1 aside owing to a loss of compression. I thought I started a thread back then but now I can't find it and so I will restart one now.
So a couple of years ago I figured the M1 had lost compression as evidenced by the kick start level spinning the engine freely as I went to start it. Oddly, the compression returned for a brief while (perhaps a week) before it again disappeared.
That was enough as the second time I was eight miles from home. I transported the bike home and set it aside.
Two years on now I want to resolve this issue and get the M1 back into running condition and I find the engine has compression again. I know this is certainly temporary until I find the problem, so my plan is to take the valve covers off for a start just to see that the springs are where they should be.
Of course, as if to spite me the engine has regained its compression which is not going to help me as I try to look for the source of the problem.
Could this be a valve guide issue? Maybe a guide that is loose?
I don't suspect a broken ring as yet, but if you guys tell me that's what it could be I will keep that in mind.
