Page 1 of 2
A couple of questions before the first starting attempt
Posted: Thu Aug 21, 2014 8:59 pm
by narrow_monza
I will probably be attempting to start my NC 250 this weekend. Before I do, I have 2 basic questions:
1) does the oil level need to be checked with the dipstick screwed in all the way and the bike on the center stand with a cold engine?
2) can I run unleaded fuel? or do I need to add some lead substitute? what octane should I use?
-Adrian
Oil-level & Fuel Concerns
Posted: Thu Aug 21, 2014 11:36 pm
by DewCatTea-Bob
[quote= narrow_monza ...
" does the oil level need to be checked with the dipstick screwed in all the way and the bike on the center stand with a cold engine? "
____ The factory's dipstick checking-method isn't very trust-inspiring (as regular dipstick oil-level checking usually goes), since it can possibly seem inconsistent.
Anyhow, MY answers are: 'no' to "screwed in all the way" ; 'yes' to motor level-set "on the center stand" ; and, 'doesn't much matter' to "with a cold engine".
__ Anyhow, if you have at-least 2-quarts in the motor-sump, then it's certainly okay to run the engine. _ (And [whilst on the center-stand], even just one quart can get-by for the short time until the cyl.head heats-up too warm.)
" can I run unleaded fuel? "
____ Yes. _ (As I don't think we've had much choice since before the '90s.)
" do I need to add some lead substitute? "
____ Ya really don't need-to, but that's probably better for the valve-seats,, however a little-bit of ordinary fuel-lubricant*additive would likely help well enough.
(* Often referred-to as 'top lube'.)
" what octane should I use? "
____ Unless your engine's piston is just a mere 8:1-CR. version, ya ought always prefer the highest octane normally available.
____ BTW,, don't forget to turn-off the petcocks, afterwards, (or-else you'll most-likely get fuel down-into your oil) !
____ Also, are you already familiar with the preferred method for kick-starting such Duc.engines with the magneto-type ign.system (so as to avoid THE much-dreaded 'KICK-BACK') ?
Re: A couple of questions before the first starting attempt
Posted: Sat Aug 23, 2014 3:56 am
by m82a1
I for one would love to hear the preferred starting procedure for the 250 narrow case with AC ignition, as I will be in the same position with my bike in less then a month if all goes to plan.
Re: Oil-level & Fuel Concerns
Posted: Sat Aug 23, 2014 4:30 pm
by narrow_monza
DewCatTea-Bob wrote:[quote= narrow_monza ...
I have 2 quarts in there now.
Hmm, interesting. Why/how would gas get in the oil?
I'm afraid I'm not, and I'd hate to experience the kickback. In the past I had push-started it, but now that I re-installed the kick-start and implemented the repair that Jim posted in the Tech section, I'm eager to use it. Please share the preferred method.
Thanks!
-Adrian
Oil-level & Fuel, plus Kick-starting Concerns
Posted: Sat Aug 23, 2014 10:37 pm
by DewCatTea-Bob
" Why/how would gas get in the oil? "
____ Fairly simple... At-least the stock side-bowl carbs are pretty-much unable to completely stop fuel-flow from the gas-tank, and-so the fuel slowly leaks into the carb.throat and drips-down the inlet-duct & into the intake-port & past the in.valve, to next leak-past the piston-rings and then run-down into the motor-case oil-sump where it then gets mixed-up with the motor-oil.
__ I wouldn't trust ANY carb to completely prevent this quite COMMON oil-contamination issue !
" Please share the preferred method. "
____ A more detailed explanation for the preferred kick-starting method has already been previously posted in at-least two other older threads, so I'll be rather brief with this response.
__ Always very-SLOWLY work the kick-lever until the cyl.compression finally conspires to slow the lever's progress. _ Then (even more patiently), keep light pressure on the kick-lever as you feel the compression bleed-down,, and as it bleeds-away towards next-to-nothing, then STOP ! _ (It may take some practice to develop the sense to realize exactly just-when to give-up squeezing-out the compressed-air and release your foot-pressure off the kick-lever, so as to not go TOO-far.)
At this point, the crankshaft position should then be as near as possible to power-stroke TDC - (or well within 10-degrees of it).
Then next, you must let the kick-lever reposition back to as much swing-throw as it can normally achieve,, and then (with your leg positioned to your best advantage), WHOLEHEARTEDLY -(without ANY timidness !) kick-down the starter-lever with pretty-much ALL your might & speed !!
That-way, not-only will your-force attempt to push the crankshaft & piston past the (rather early) point-of-ignition,, but ALSO, (and most importantly), the flywheel will then much better store your inputted momentum-energy to greatly help overpower the (dreaded) early ignition-force, and continue-forth onward to normal engine-rotation (and hopeful start-up).
Otherwise (if ya don't care to take such patience),, the commonly done rather randomly-set kick-start technique will most-certainly often turn-up a quite unfavorable 'snake-eyes' chance-result, with the UNDESIRABLE kick-BACK (that's normally inherit with Ducati's mag.powered ign.system) !
____ Have you ever checked to see if your particular Motocross-motor has any AAU connected to the points-cam ?
Re: Oil-level & Fuel, plus Kick-starting Concerns
Posted: Sun Aug 24, 2014 4:52 am
by narrow_monza
I make it a habit to always close the petcocks but wasn't aware fuel can make it past the carb float bowl. Thanks for the warning.
Great info, will practice this approach and hope for the best ;)
Yes I have an AAU of type AA367B. By the way, does it need to be oiled?
Posted: Sun Aug 24, 2014 8:52 am
by DewCatTea-Bob
" Yes I have an AAU
does it need to be oiled? "
____ I'd just give it a light-coating of grease from a spray-can.
Posted: Sun Aug 24, 2014 12:56 pm
by Nick
Starting: Put bike in gear, roll bike backwards until piston comes up on compression, put in neutral, kick.
Posted: Sun Aug 24, 2014 8:25 pm
by DewCatTea-Bob
Nick wrote:Starting: Put bike in gear, roll bike backwards until piston comes up on compression, put in neutral, kick.
____ This can possibly be a faster method that's also easier to learn & master, than that which I've suggested (which allows near 700-degrees of engine-rotation to build-up flywheel momentum),, however this-way provides about 20-degrees less rotation (which shouldn't matter much to anyone over a 150-pounds in size). _ In fact I-myself had come to use this particular kick-starting prep.method after I got a 10.5:1 MC-piston installed !
With a 8:1 piston, this prep.period is probably no faster to get accomplished,, however may still be easier to learn to do.
Posted: Mon Aug 25, 2014 12:08 am
by narrow_monza
Speaking of pistons, is it possible to identify the piston in my bike by reading what's stamped on the top part? I can see some digits/letters through the spark plug hole.
