John,
Check the photo I have attached. This yoke is from a 1965 Mach 1. I think your model has the same components.
There is no thread, the bearing ring is a light press fit on the shaft. I removed my bearing ring by just tapping with a hammer and drift, at opposite sides alternately. I didn't use heat, but this would be an option if it doesn't budge with light blows.
Heating could be done in an oven, say to 200 degree Celsius, and then chill the shaft with a wet cloth. Hold shaft in vice (not on thread), and then tap it again.
The yoke is cast steel. The shaft is 26mm diameter above and below the yoke, so I think it either a very heavy shrink fit in the yoke, or is bronzed into it. Alternatively, there may be a shoulder on the shaft, the bottom of the yoke counterbored to accommodate it. I cannot see this shoulder, the paint is thick. I think this would be a more sensible design option. If they did this, there would only need to be a light press fit, which is cheaper than a heavy press fit or extra work of bronzing. Has any one got any further knowledge of this?
The reason I am asking is that my yoke/shaft is missing the travel stops. Someone had a yoke/shaft on e-bay with a cutoff shaft. If I was sure of the connection method, then I could marry the two good parts. Top thread of shaft is M26 x 1.0 pitch.
Stewart
