Best Lube to Use in the Shift Box
Posted: Wed Mar 20, 2013 10:02 pm
by blaat!
Searched this topic, but couldn't find much... What is the best lube to use inside the shift box?
Thanks!
-Jim
Re: Best Lube to Use in the Shift Box
Posted: Thu Mar 21, 2013 6:11 am
by joe46ho
This is what I use...
It is kind of pricey, but I keep it around for parking brake linkage, and drum brake backing plates on cars & trucks...
It is synthetic, contains moly, PTFE, and graphite, its also waterproof. The main reason i like it is it doesnt seem to dry out, and has a very broad working temp. range (-40 deg. through 500 deg.) There are a ton of other products you could use, i have no idea what ducati originally used it seems like they used "motor oil" for everything if you go by the book. I would think any quality lightweight grease would do the job though.
http://www.crcindustries.com/ei/content ... =05351&S=Y
