My first Duke (and my 1st post)
Posted: Sun Feb 03, 2013 8:02 pm
				Hi to all
I've read posts on this forum for some time now, but finally as it looks like I'll be able to work on my little Duke I trout I should join.
So here is my first post and a short story of my sweetheart.
I bought my Duke in the UK in 1974 when I was 16. It was advertised and registered as a 250 Mark 3. As a teenager having limited resources I didn't know better, or much about Ducati's - except that I wanted one.
My father loaned me the money and it was mine. It had a round style tank, a Mark 3 seat, said Mark 3 on the steering head sticker, and had triangular tool boxes. The fact that it had square style fenders meant nothing to me.
It even had a Vic Camp fairing, but wasn't too fast.
After talking to the local 'experts' I soon learned how to make a Ducati go faster - install a 30mm Amal carb and instal a hi lift cam.
Done. The cam came from Wittey Ducati.
Base circle is 20.9mm with an inlet lift of 10.34mm and an exhaust of 9.68mm.
Surprisingly it ran and idled. It ran pretty well. I soon learned that it had a small valve head and lower compression piston.
My Duke wasn't what I thought. It was a 'Bill Hanna' 250 Monza' that was surplus to requirements and went to the UK an long with a few thousand more, but was registered as a Mark 3.
After a friend crashed his wide case 250 I inherited the piston and head, which I grafted onto the bottom end, changed the cam to my 'special' one and used the 30mm carb.
Now it was quite fast and a lot of fun.
I'm now rebuilding it. I decided to continue the Mark 3 route. I picked up genuine fenders from a dealer that didn't appreciate what he had. Less than $150 for the pair. Just need to get the chrome off. The front is the correct narrow one.
Don't want to make this very long story too long, so I'll ask for help now.
I have 2 more cams that I'd like identified.
One has white & green paint
Base circle is 20.8 mm and 9.95mm lift on the inlet - 20.98mm and 8.53mm lift on the exhaust
Sounds like a white & green one to me.
The other that I was told is a gray cam is
Base circle of 22.9mm and 9.04 lift on the inlet -23.2mm and 8.31mm lift on the exhaust
Is this a gray one?
My final question for today. What is the barrel height for a narrow case Mach1/Mark3 ?
Is this a gray one?
