Transmission Retaining Rings
Northracing
Postby Northracing » Fri Oct 02, 2026 3:34 pm
I've had to do some work on the layshaft of my 350 transmission requiring me to remove and eventually replace the retaining rings. I have found the retaining rings hard to remove. I have a pair of pliers made for gripping external retaining rings ends but they'd slip off as soon as I tried to expand the rings.
I did get them off by sliding 3mm diameter steel pins under the rings and sliding them off along the pins.
My question, is there a better way to do this? Better yet, is there a type of pliers available that can grip and hold the ends of these rings?
Thanks in advance.
Derek
:shock:
Re: Transmission Retaining Rings
Postby Duccout » Sat Oct 03, 2026 10:24 am
Hi Derek,
They are a pain to remove. I bought a pair of circlp pliers from eBay that did work, but I don't know if they are any different to what you have got. Mine have a sort of flat blade on each jaw that slips under the ends of the circlip.
Postby blethermaskite » Sat Oct 03, 2026 1:37 pm
The last time I had to remove one of these I ordered a couple of replacements from Nigel lacey and broke the old circlip off, my previous experience of getting these 'off' was so difficult I kinda over expanded the circlip and ruined it......I like your method of sliding it off over pins :) :) . Cheers george
Northracing
Postby Northracing » Sat Oct 03, 2026 5:43 pm
My removal method appears to have stretched the retaining rings beyond reuse, new ones on the way.
I have a set of more modern pliers on order with what looks like a bigger surface area to grip the rings, if only for installing new ones.
Hopefully not a job that needs doing often.
Derek
Users browsing this forum: No registered users and 178 guests
